Re: Normal Operating Temp
1 - trim - needs to be adjusted only to read full down when the drive is in fact full down, if thats not the case, adjust as neccessary - the sender is not designed to read according to the increments on the guage, only to read full down when drive is fully down
2 - true that on the temp, but get a good look at it when at operating temp and remember the reading, if it goes higher = trouble
3 - fuel, yep will fluctuate but if really bad could be a faulty sender, or no baffels in the tank
4 - speedo, yeah right, you wanna go faster, drill the pitot hole bigger
5 - oil (same as temp)
6 - tach - should be pretty accurate, if not - yep, wrong setting or faulty tach/circuit
7 - volts, i see guages that read all over the place - some really high, some really low, best guage is a voltmeter at the alt/batt/back of guage
as far as rating accuracy, i don't have a preference, ive seen every guage read innaccurate, the two you need to be aware of at all times is temp and oil
