Re: nosecones on outboards
thanks for your input , i wasn't aware that the real reason for a nosecone was hitting the upper 70's to prevent blowout. i'm only in the mid 60's and thouht the nosecone was just to cut thru the water better . i had seen one type that you install on your original lower unit and was looking for some cheap speed .i think i do need to raise the motor up a little , it won'ts to walk some at full trim and wide open which is around 5600 rpm .
