Restoration man
- Joined
- Jun 14, 2012
- 73
Hi all My 5.7 1989 mercruiser that has not been started In 5 years
"a house build got in the way,
I winterised it when I left it, when I tried to start it was seized so I put some wd40 in the bores and left this for a few hours and it unstuck it ,then just to be on the safe side I injected a little bit of engine oild into each cylinder and left the plugs out and continued to hand turn the engine over by hand , then i spun it over on the starter and a bit to get the oil pressure up, re fitted some old crap pugs i found in the boat and fitted a old outboard motor petrol tank directly to the fuel filter and with some fresh petrol in it to my amazement it start, iam running the engine with the drive removed with a hoze connected directly to the engine with a home made fitting , all seemed good But the the engine seemed to be steaming out of the rocker cover breathers quite a lot, I put this down to maybee there was some condensation in the engine so when it was up to temp so I changed the old oil I just put some new cheap stuff in there and a cheap oil filter but it is still doing it and also I can see what looks like a kind of a air leak or something in the seal between the inlet manifold and the block at front of the engine little bubbles , I'm now worred I may have a cracked block in the valley ? The rest of the bock looks fine bone dry , also i have been running it with the thermostat removed so i know the water is going round the bock ,There is no water in the oil and I've left it running on the hoze for a good hour and all is well other than that what do you think ?
