After researching it further, I think you are right. I did post the wrong model number and it should have been E90FPLSIF. I cannot find a part called a Regulator/Rectifier listed so it must be in the stator. I was hoping you were wrong as I did not want to replace the stator.Read post # 4 again. You should take this into a dlr and have a laptop put on it and see what codes come up. You could also have a bad stator.
Would replacing the stator solve the problem?As said before the reg/rect is part of the EMM.
Maybe, maybe not. As i said before, have it checked out on a laptop. The lap top will check voltages at different points.
You may want to check all the fuses in the PDP panal.
All fuses were good but their are some relays mounted in with the fuses. Would any of these be a possibility? I have ordered a manual for this and maybe I can find something in there.
