Not firing....
Justin H
1994 Merc.115 HP no fire to any of the plug wires.<br />Checked all the grounds all good. Could it be the switch box? Where is it located?<br />Thanks for your help.
elklake
Re: Not firing....
switch boxs are on the side of engine block. all most all wires go to it. No spark could be anything i have found out from key switch to mercury safty switch.If you go through forums there is a lot of good info.
