I have a 1958 35 super seahorse that I replaced the impeller and thermostat on. The impeller is going the right direction but for some reason it is not pumping water. Any ideas on what to look for it was pumping water before I changed it.
That motor does not have a telltale outlet. After the thermostat opens,it should spit out the opening on the top of the midsection. The spit should be about 140*F. Most of the water is discharged behind the prop.
Where were you looking to see if the motor is pumping water?
I ran it for about 5 minutes and I was looking for the Mist in the midsection and was getting very very very little. So I took off the cowling and the motor was hot. I then remove the thermostat and there was no water in there are just a little steam.
Yes, try that and if no water comes out, drop the lower unit and hook up a garden hose and see if water comes up to the thermostat housing. If not, there is a blockage. If water comes up, the problem is with the water pump.
