ddbyrd3
- Joined
- May 9, 2005
- 369
I have a 1981 Johnny 140 V4 J140TXCIM.<br /><br />Compression is 109 - 115 on all 4 cylinders, I have great spark, carbs were rebuilt last month, Butterflies are at full horizontal position full throttle)fuel pump was rebuilt, and all lines were changed. Coils and power packs are all new. Static timing is set at 24* (tested on the trailer in the water, per DHadley's instruction) and the timing base is moving free to the stop.<br /><br />My question is this, The motor (prior to rebuild in "01") use to run at 6000 RPM running a 13 1/4 x 19 SST prop. I had it out again yesterday (same prop) and at full trim it will only pull 4800 - 5000 RPM full fuel, myself and 2 of my boys. (standard load)<br /><br />My tach is a teleflex set on the proper setting (per instructions)the motor location on the transum did not change, I am scratching my head as to why I cant get it to pull in the 5500 - 6000 RPM range. <br /><br />I do intend on taking it out again this weekend using my 13 1/4 x 17 Aluminum Hustler prop to compare RPM. <br /><br />Any ideas???? Sorry for the long post....
