alwayzfishin
- Joined
- Jul 19, 2010
- 3
I have a 1981 Starcraft CC with a 91 Evinrude 88 SPL for power. The problem is this: it does not always reach full speed after getting on plane. Usually after being on plane for 15-20 seconds she settles down and takes off like a shot. Just had a new prop and hub kit installed to match the original. All 4 cylinders test ok for spark and compression. No water in the bottom of the boat, and no excess of equipment on board. Only other thing I can think of is a stretched throttle cable. New fuel filter in-line and also use Star-Tron. Boat does not have trim tabs and adjusting manual engine tilt only changes the hole shot speed. Is there anything else simple I might be missing? I have a good mechanic, but don't want to pull the boat if I don't have to, for obvious reasons! I have a tach on order to check the RPM's but I'm hoping someone has an item on their checklist that I don't. Thank you in advance!
