Not shifting to reverse / 1978 Mercury 500 Thunderbolt 50HP
lgaytan
Hello
just recently I had issues with the motor to shift to reverse gear, no issues to forward only to reverse. It seems it wants to shift but makes some grinding and dont engage fully. Is there a set up procedure for the shifting cables any one can share?
Thanks
Chris1956
Sure. Disconnect the shift and throttle cables. Set motor to neutral. Set contol to neutral. Now turn shift cable adjuster until it fits onto shift lever.
Reconnect throttle cable.
lgaytan
No, it just stopped working, I think I know the issue now, they are completely damagged in all the liner, probably this are 40 yesrs old or more. I will change them how ever I dont know how to select the new ones, what should I messure? The complete length of the cable? If doing that I mesure 13' 5“, would that be a 13' cable or a 14'?
Thanks
lgaytan
From the controls to the transom my boat is 8' and from that side to the center of the motor another 2', my cables were doing a very big curve when installed so probably this were too long, how long do you suggest to order new ones?
Chris1956
The cable OEMs usually have a formula for that. Teleflex was a large OEM. It looks like Seastar bought out Teleflex. I would try their website.
lgaytan
Thanks merc850 this is the information I needed, it's strange that measuring from anchor hole to anchor hole I got 13.5' I thought they were not produced in fractional sizes, anyways with the measurements from the boat 8' + 2' and adding 18", this should be a 12' I guess.
lgaytan
solved with new cables, definetely the not shifting was due to the very damaged cables I had, I got the 13' same as the ones it had before, I think they are too long but I didn't wanted to risk going for the shorter ones.
