sandrin olivier
- Joined
- Jun 11, 2007
- 12
Hi,
first just to tell you that my boat is a inboard sunray 1989 with 3.7LX (180hp) and alpha one drive with Thru Hub Exhaust & 15 Tooth Spline, 4-? Gearcase.
it's a 18,5 feet with a mini cuddy ( mostly for storage), it's a pretty heavy boat for it size. the actual blade is a 14? inch 19p. ( i should say the actual blade was...)
the boat run cruising speed of 42-44 km/h ( around 28-30 mph i guess) at 3400-3600 rpm, the top speed is 64 km/h ( around 42 mph) at 4700 rpm . also the fuel economy is not the best at cruising, maybe because of the 4bbl. maybe it's just a feeling as i do not investigated this a lot.
after 4700 rpm i notice almost no difference in speed up to 5200 rpm. i take all my speed with the gps.
the boat plane ok but not as fast as i want, but not terrible too. i have to go very progressive on throttle or i feel the boat will almost sink right away if i push the throttle too fast. this happen even with only 2 person.
this week end, i hit a rock in the lake and the prop lost some blade part. now i wonder for replacement should i look for a different prop. the actual is a 3 blade aluminium quicksilver prop.
my goal is to get the best cruising speed performance ( that mean great fuel economy at the fastest cruising speed). there is many brand and model, it's hard to find what fit me best. i also want a model of blade that can take the most of the hit if this happen again, i mean what is the best hub system.
the other thing, the hit... generaly speaking, with this stern (alpha one) what is the most commun thing to be broken or damaged inside? i know i still fonction because i had to come back to the dock with it ( for like 3-4 min ride)
thanks for helping,
sandrin
thanks for helping,
sandrin
