Re: not successful 2 dropshot
I had to start a new post to get help. Now im trying the dropshot with no success. I think my palomar knot is tied
right. But it looks twisted and seems to make the lure swim in a circle. With The worm on the hook it tends to lay down more than be horizontal. I cant seem to find a really good video of how to tie this knot.
Maybe you don't understand how drop shot works. You don't retrieve it to fish it. It's almost like bobber fishing on the bottom. The lure is neutral to slightly buoyant, and the weight locates the lure a set distance off the bottom. It can be fished right under the boat, or on a long cast depending on circumstances. I find it to be the killer technique in clear water when the fish are just off the weeds, deep, and not real aggressive.
Any plain hook will work. Sometimes a little extra shank length, like an aberdeen hook works a bit better.
Cast to the target, let the rig sink straight to the bottom, with the rod high and a little slack, shake the rod to make the bait wiggle. If it's in front of ms bass, she's eventually going to eat it just to get rid of the irritation. Patience helps a lot, and so does a good scent, like Kick-N-Bass.
When the fish takes the bait, it's a leisurely thing. Watch for the line to move, and set the exposed hook with a sweep set, not a hard yank like with Texas rig.
