BigBabyLou
- Joined
- Apr 9, 2002
- 129
I searched this forum and found some links to websites which calculate the right prop size for a boat. Mostly, the result for my 26' minicruiser w/ 460 OMC King Cobra was 15x15. That's what I have right now (it came with the boat).<br /><br />Still, the boat does not reach the WOT RPM's when going at full speed, I hardly get up to 3000 (the WOT range is 4400-4800).<br /><br />I tried to troubleshoot the engine and other components and everything seems to be all right.<br /><br />I would like to get another prop with less pitch or smaller diameter and see what effect it has on the RPM's. But what do you think, guys, if I can't find a suitable prop with lower pitch, should I try smaller diameter? (BTW: I will try the two piece prop - separate hub and separate housing, it's probably the right way to go)<br /><br />Thanks in advance for any responses<br />Lou
