cjustinstockton
- Joined
- Sep 13, 2017
- 9
Hi, all. Long time reader - first time poster.
I have a Mercruiser 5.0 MCM carbureted sterndrive that I just had the carb rebuilt on. I had the local repair shop do the rebuild. When I put it in the water for the first time after the rebuild, it started right up and was running just fine. The idle seemed smooth and it was running okay. That is, until I got into the upper RPM's. When I tried to run it at WOT, it hit about 4,000 - 4,500 RPM's (wasn't really that wide of a range, I just didn't look at the exact number) it would run there for a second and then it sounded like it was starved for fuel and cut back about 500 RPM's. After a few seconds, it would surge back to the higher RPM's. The higher I put the throttle, the more frequent the intervals of this happening. I finally found a sweet spot of about 3000 RPM's where it wouldn't cut back but every so often.
I didn't want to just assume it was the carb that was just worked on even thought it didn't show any of these symptoms before. So, I did a few things before calling the shop. I replaced the fuel water separator, emptied the tank and filled with 93 octane and put some dry gas into the tank.
Long story short, that didn't work.
I took it back to the shop and after they got a chance to look at it, they told me that my fuel pump's internal regulator had failed and it was reading at 12 PSI of fuel pressure. They said when I'm hitting higher RPM's the engine is flooding. This just doesn't make sense to me given the symptoms. If it's blowing the needle and seat, shouldn't the symptoms be WAY more noticeable at lower RPM's?
My first thought was that the floats were not adjusted correctly. Because the fuel pump is internally regulated, it's a $300 part with another $200 in labor (even thought from the looks of it, it's about a 20 minute project). I don't want to spend this much for them to NOT fix the problem.
Thoughts?
Thoughts?
