Not sure what to do..
zach103
Alright.. heres my problem.. i tore out the carpet on the floor and sides to redo the floor.. well now im not sure what to do with the sides.. im starting to take off the glue and the sides not perfectly flat..im not sure what to do.. will the paint will in the divots and what not?.. what have you guys done??
Gary H NC
Re: Not sure what to do..
Good old 80 grit sandpaper and an orbital sander..
If you plan on painting it get it as smooth as possible.
If going back with carpet i would still sand it down some and clean with acetone.
3M spray adhesive and put the new carpet on..
oops!
vynal is another choice zach.
fixb52s
Be carefull when you sand. A lot of boats are foamed on the sides, and have a very thin layer of glass on it. It is easy to sand right through it into the foam.
I put carpet back over mine.​
dvan1901
When I re-did the floor on my other boat, I just put carpet back on the sides, but I used non-skid paint on the floor. Looked good.
zach103
what color did you do for the carpet?
ezmobee
Go with a color that doesn't show dirt well. Beige, gray, etc. I used navy and kick myself for it all the time.
dvan1901
My boat had navy carpet and I pulled that out, but like I said, left in on the side because it matched the vinyl. I painted the floor a medium grey.
