Not Sure where to start trouble shooting
Mudboy68
Hello All,<br /><br />I hope someone may have had this problem before because I'm stumped.<br /><br />I Have a 1970 115 Evinrude electic shift on a 16ft canbar bowrider.<br /><br />I tuned it up in the driveway uning a 45 gallon drum (found cups jut don't do it)and it ran great after setting the link and sync and adjusting the timing advance.<br /><br />Took it out on the lake sunday started great but when I put it in gear it's like 2 cylinders stop working and if I throttle it up too fast it will stall but if I open it up slowly, About half throttle all 4 cylinders kick in and away it goes and it runs great until you throttle it back. If you throttle back too fast it stalls if you throttle back gradually it slows down and at half throtle again it's like it is running on 2 cylinders again if you shift into neutral it Idles and throtles up just fine.<br /><br />I'm at a loss any input would be great.<br />Thanks <br />Brad
dc in ms
Re: Not Sure where to start trouble shooting
It sounds to me like midrange jets in carb are clogged ( if it has mid range jets) or maybe it's flooding for some reason at that throttle range. Maybe your choke valve is activating when it shouldn't. Possibly loose wiring causing short??? <br /><br />Good luck
Walker
I guess carbs too. Tear them down and give them a thorough cleaning. Do a search on carb cleaning
jtexas
See if you can recreate the symptoms with it running in the barrel. If so, then pull the spark plug wires one at a time (use a plug wire tool or somebody you don't like too much, to avoid getting shocked). If the RPMs don't change when you pull the wire, that's your problem cylinder. Before disassembling the carb, I'd check for spark - no spark, it's an ignition problem.
