Ristin
- Joined
- Aug 4, 2017
- 58
Recently purchased a really clean & mechanically sound 1984 Seaswirl Sierra. She's my first boat and so much fun. Has the 3.8l OMC stern drive and she runs magnificently.
However...(there's always a however right?)
She has a 31 gallon fuel tank mounted under the floor just forward of the engine. The filler port and tank vent are mounted horizontally through the transom near the top. The two times I've filled the tank I get a blast of fuel spraying out of the vent just as the fuel nozzle clicks off.
The first time I filled the tank I stuck the nozzle in and went full bore. When gas sprayed out the vent it got on my pants and shoes, and ran down the transom getting on the bellows and silicon around it. Estimate it was a cup or two..
Next fill up I set the fuel nozzle at the first click and tried filling slower. As I heard the tank get full I reduced the flow rate as slow as I could. She still blew gas out the vent when the fuel nozzle clicked off. This time I was standing to the side ( maybe you can teach an old dog new tricks) but gas still ran down the transom and onto the ground.
After fill up she doesn't spray gas out during transit even on bumpy roads.
Any thoughts on what to check?
My shade tree mechanic side was thinking of taking the vent off and putting a thin plastic or metal piece between under the vent housing and fiberglass to deflect the spray away.
Fortunately the side of me that likes to fix things properly came to this site for advice.
Thanks
Thanks
