I have a project boat with a newly rebuilt 454 engine that is not quite fully installed in it. Long story short, my boat cover failed and rain water got into the carb and subsequently into the cylinders. To make matters worse we just had multiple freezes this winter and now I'm wondering if the block to my brand new engine is now toast. Are the cylinders walls typically strong enough to withstand water freezing in them? Should I finish assembling the engine so I can run it and check for water in the oil? Or should I start tearing the heads off (yikes!) in order to inspect the cylinders? Thanks in advance for any help.
