beermunk
- Joined
- Jun 20, 2004
- 146
okay, so it's been awhile since my last post on this motor. 1978 35hp evinrude<br /><br />my original problem was that after a day of running, just as i was getting home, the motor sounded like it went into high revs and then just killed. it wouldn't restart without waiting for a bit and then it ran real rough for only a few minutes and then it would die.<br /><br />so i've replaced the primer bulb and hose. i've replaced the spark plugs and bought some decarb to run through it.<br /><br />just fired her up this morning (after replacing the plugs, and she still sounded rough but then started to sound a little better, although the idle was still really high compared to normal. <br /><br />i let it run and it seems as if the decarb was doing some good, as the trashcan that i had the motor sitting in now contained tons of black oil on top of the water. i dumped it out and refilled it. <br /><br />on the fuel mixture, it says "normal 1 1/4 turns out" so i started messing with the fuel mixture, all the while the engine is sputtering out all this black crap.<br /><br />then it died and hasn't restarted since. i have taken out the plugs a bunch of times and cleaned them off, and set the fuel mixture back to what it was before, and have waited a few hours in case it was flooded.<br /><br />i'm now stumped. it sounded like the motor was about to run good again, and now it won't start. any suggestions?
