maverick974
- Joined
- Jun 26, 2009
- 122
A few months ago, I got a 1995 Spectrum Pro Avenger. A 17 footer. Aluminum hull, dry weight of 940 lbs, a 1995 Force engine, 90 hp.
Right now it has a 13X19 aluminum prop on it. With 2 guys, half a tank of fuel and a little fishing gear, I'm getting just shy of 40 mph with the RPM's right at 5400.
The max RPM for the engine is 5250 and if I could, I'd love just a few more mph out of her. I'm guessing I need to go up in pitch an inch or so but there is also the question of prop style. I've been told a stainless prop won't improve things much on such a small engine and if that's true, then we can eliminate a SS prop. So that leaves aluminum or one of the composite props. I installed a comprop on my last bass boat a few years ago and to be honest, I was very pleased with it's performance until my brother snapped all four blades against the rocks because he didn't tilt the engine up. Not the props fault as it was supposed to break away to save the lower unit. I'm sure it would have killed any prop that was on there and no damage to the lower unit.
So I have two choices. A different aluminum or a composite.
Any suggestions on what material? Next is pitch? 20? 21?
If I find the right prop, what differences will it make and will I see any speed improvements? Is it even worth the effort for 1 or 2 mph?
Thanks.
Thanks.
