1979 evinrude 55 HP
Well gotten everything Back together again. However now the engine hesitates from idle to wot. I've went through the linc and sync and now ideas now. Carbs are clean (replaced the top carb all together with a factory one).. check.. replaced all the gas lines...check... link and synced and all carbs are running great check. MY problem lies from idle to midpower. I have to fast start it to get it started sometimes and then when it gets running good. Can shfit it and it starts to die and then when I get it over half catched and boy do we go. Heres what I had to replace: I had to pix the powerhead to exhaust plate, the thermostat, for good measure, the head gasket for even more safe measure, the top carb because the jet was stripped out and I was was tired of tinkering with it becuase it was sucking at idle. So any ideas, workings to do would greatly help. The copression is 150 top 145 bottom.
