Now what did I do....
Beefer
1959 Johnson QD-20 10 hp
Long story short- there is leakage from my lower unit. I was trying to get the flywheel off, and later I noticed the fluid leak. Had it in gear trying to get flywheel screws out. Did I break something? I will eventually get around to opening her up, but don't want to start another project at this point, just want to know what the likely cause is, and what to look for when I do open it.
Re: Now what did I do....
what does it smell like.....honestly not joking. gear oil has a funky smell, unburnt gas has a gassy smell.
Beefer
It's definitely gear oil
10hp did you tip it on its side when you was working on it? might just be a leaking seal and when you tipped it the oil ran out. either way its time to take the lower off and see where the oil came from.
kfa4303
Banned
