shellbackII
- Joined
- Jul 10, 2011
- 5
This started late last season, I replaced the plugs took it out once to check before winter and it seemed to be solved. Ran stabilizer thru it and put outside for winter. Brought it out this season, fresh tank of gas and some Seafoam engine treatment, bring it out to the lake... and back to the way it was last fall before changing the plugs. Boat can barely can get away from the dock and has to come back, but seems to run fine at home on the hose. Thought it was gas flow ( filter was somewhat plugged) so replaced filter and fuel pump. No change. Revs up great at home, you think you have it licked. There is a very slight sense that something is kicking in and out electronically, but pretty much seems to be running up to par.... BUT ON THE LAKE..it will start up right away, run smooth, and idle...just don't ask any power from it, put it in gear...it kills or at best can idle. Try to accelerate..it kills. Could it be the 250.00 dollar CD ignition unit?
