ns90a
Moondance
Needing to replace water pump on the NS90A, have all 6 bolts out and the gear linkage off. But the LU will not lower at all, is there something I'm missing? Annoyed
pvanv
Water pump repair kit. Includes all parts needed to replace water pump.
Fits: 90A 2-stroke model. Part #: 3B7652311M MSRP: $99.37
The drive shaft is stuck in the crank. You need wedges and patience. Much patience. Do not hammer on the LU; it is easily cracked.
Moondance
Thank you, running out of patience after finding the secret 7 bolt. It also is stripped and rusted. Staying positive and patience. tks.again
Moondance
Hello Paul, thanks for the good advice, wedges and patience did it. But now I can't get the old housing out. Try prying,soaking in Blast,vise-grips, and cutting. Afraid of cracking the mount. Am I missing something? Thanks
pvanv
Do you mean that the water pump case is stuck in the LU casting?
