Number 1 cylinder not firing - 1984 70 hsp Johnson
bmontymi
The number 1 cylinder on my 1984 70 hp Johnson is not firing. I have replaced the coil. Still no fire. Any ideas on what might be the problem? Thanks, Doug
Vic.S
Re: Number 1 cylinder not firing - 1984 70 hsp Johnson
Not firing meaning you have a good spark but still not firing? If so have you replaced the plug or checked the compression.
Or not firing meaning there is no spark? Now suspect the power pack, but check all electrical connections
Good spark new plug & good compression. Top carb not getting fuel or in need of a clean?
Did you not check the coil by swapping them around?
tashasdaddy
more claification. to vague to answer properly.
