Keith Buchanan
- Joined
- May 10, 2004
- 221
Hi Guys.<br /><br />Been a while since I have had any problems but here goes.. 1989 50HP 3Cyl.<br /><br />Started loosing power on number 3.This problem is intermitent in the fact that it will surge at full power for a brief second or two then bog down. Swapped over coils no change, swapped over input to switch box no change still weak combustion on this cylinder. Compression test good, carbs cleaned, reeds intact.Recent pump diaphrams, new high tension leads plugs etc,etc. My attention is now been drawn to the trigger or timing. Any pointers before I pull the red stator off.<br /><br />Regards all...Keith B.....
