ronnyd8719
- Joined
- Jul 24, 2006
- 4
Hi I am new to the forum and old and dumb. Well not that bad. I need some help. I have a 1981 mercury 70 hp. I have been in and out of the hospitals in the last couple of years. To get started. A couple of years ago I was trying to get my motor running again. I had clean the carbs. and I was putting it all back together and I fell out the boat trying to get out. Well I went to hospital AGAIN. Now it is present day. 4-052009. I had the boat sitting with out the carbs on right and sitting for over a year that way. I have clean and ajusted the carbs again. I get the motor to start by the hardest, but I get no fuel to number three cylinder. I have fire, but the plug is clean and new when I pull it after starting the motor. The number one cylinder has a little carbon build up and number two cylinder has more than one and three is clean. I checked compression in number three cylinder and the compress is about 124 GOOD. I thought about the reed valves, but the fuel is not being forced out the front of the carb. One thing I have thought of but did not check at this time is a dirt dobbler making a nest on the reed valve. So this is still possible.
The motor is strange it has two carbs and three cylinders. and in this case I find it strange for one and two cylinder to get fuel and not three. Can someone help a old, dumb , and crippled man with a motor that has a cylinder that will not get fuel.
Thanks Ron
Thanks Ron
