I finally had a chance to get on the water yesterday, and was wondering if someone could check these numbers to see if they sound about right, or if I should consider a different prop size:
Boat is a 1995 Sea Ray Sundancer 250 w/ Mercruiser 5.7 L. carb 250 HP. Leg is a Bravo 2, spinning an aluminum 3-blade 17.5x23 mercruiser prop.
At 3200 RPM, GPS speed is 22-23 Kts. WOT gives 4500 RPM, GPS speed 38 kts.
Light load, on the plane in about 4-6 seconds.
Expert opinions appreciated!
