numbers on force prop
bobmoore
the numbers on my prop are p692 and then 692265 these are on the hub then there,s a number on the side d311 and a 15 stamp on the other side,the prop measures from center to end of blade just about 6.50 is this a 13x15 prop or 13.25x15...thanks
sony2001
Re: numbers on force prop
Bob, you seem to have an origional prop. My hand written notes say its a 13.5X15. The OEM part no. is 48FP692-1. Michigan # is 072127.<br />Do you want another one?<br /><br />------------------
bobmoore
you are right . i took it to the local prop shop and thats what he came up with,the prop looked good,but had a few marks on it ,he checked the bal. of it and boy was it off ,so i bought one of them composite ones with 4 blades ,and wow very smooth running.thanks.........Bob
sony2001
I should see if anyone around here can check the balance then grind it down. I too found a Comprop. Waiting to recieve it. Do you use anti-seizing compound or something else.<br /><br />------------------
bobmoore
no i don,t .but i,m not happy with it ,it slows down the boat 4mph,s
