ny benefit to FISH finder over depth gauge for runabout?
USA_boater
I bought a deep V four winns that I am not planning to use this as a fishing boat (although I might fish for catfish from time to time). The existing Humminbird fish finder it came with isn't picking up the transducer so either that is bad or the unit itself is bad.
In deciding a replacement, I am wondering if a cheap depth sounder is just fine for my needs with this boat. OR is there some blindingly obvious reason I am missing why I'd want another full-featured unit???
roscoe
For few bucks more you can buy a sonar with chart plotter , if that would have any value to you.
Silvertip
Know the water you boat on (check maps) and you don't need either one. But considering the little cost difference why not go for something you might use -- if only occasionally.
dingbat
It depends on where you boat.
If your a small lake boater the need of a chart plotter is minimal.
If you boat open waters then a chart plotter is an essential piece of equipment.
The body of water I boat on covers 4,500 square miles. I can end my day 60-70 miles from where I started. With a push of a button I instantly have a course back to the dock with an ETA
JASinIL2006
It's nice to have a GPS-based speedometer (especially if you pull skiers or tubes), but if you don't ever venture away from familiar waters, a depth sounder is fine. Mine is a very low-level plotter, but it has maps available (for purchase, on SD cards) for most waterways. Mine has Midwest lakes and rivers, and it's really handy on the Mississippi and Illinois rivers. It shows wing dams and everything.
USA_boater
Well I'm sure 99% of my boating will be on lakes familiar to me. There are some larger lakes here that I do not know but I could use a map if I had to. The sonar would be very cool though just to see what's down there. I'll do some research but perhaps I could do the sounder as a cheap fix and then add a sonar/gps later when there isn't so many "things" to fix/buy for this new (to me) boat.
