Re: O/b vs I/b all things equal
Ok, I know this is tough question, but I'm going to ask anyways! All things being equal, same boat, same load, same water conditions, same prop, etc etc... How do the fuel consumption compare with say a 150hp o/b vs a 4.3 I/b?
Thanks
Reading the question closely...
This is a hypothetical question; Leaving reality out of it!
The same boat at the same weight, going the
same speed, in the same water, is going to be (wait for it!) the same!
Power is power! THE I/O has an addition 90 deg bend in the power train.
The 4.3MPI makes 220hp and likely gets better gas efficiency than the equivalent 4 stroke Carbureted Outboard.
The same 4.3L motor is rate at 190hp with a carburetor.
A 2 stroke motor will have a higher output per pound at the cost of lower fuel consumption.
A turbine would be even worse yet! But much lighter!
So our theoretical 4.3 throttled back to 150hp will be just about the same as our theoretical 150hp Outboard.
Now, reading through the question, The 4.3 is going to burn more fuel (MPG, MPH) than the 150 OB at WOT, But it will be going faster.
They will similar if you slow down the 4.3 to the same speed as the OB.
All things will never be equal in the real world.
Your actual mileage will definitely vary!
