obj rear admiral need more advice
blitzman17
obj checked everything u said to check not leaking in carb throats no visable leaks or connections changed primer ball and fuel filter the hose that i cant find is a recir hose but still dont cant find where it goes,like i said previos post that w should i spray some carb cleaner in carbsI m oging to have a mechanic look at it ijusthen i continue to go 10knots tops then it starts to gofaster or should i say gets on plane engine doest niss or bog down just nopower to get on plane ,some one told me it might be bad fuel told me to change plugs i pulled one it looked ok i going to have a mechanic look at it runnig out of solutions i m going to have it looked by jersey cape marine do you know fi they r reliable? if not can u reccomend any one in capemay areanoly had boat 2 seasons nice boat thanks ps primer ball still doesnt get resl hard when you first prime it when just starting up ,should it it still remain hard or firm when started
D
DJ
Guest
Re: obj rear admiral need more advice
benthooks,<br /><br />Please add this to your last post. Keep that thread running. We have no idea what you are talking about or what has been done or suggested.
