I live in central AZ. I am having a hard time finding a source for true marine plywood. I need your help finding the closest source, or, if I have to ship it what is the best source you have found and best shipping method?
2. I am seriously considering using the best 3/4 plywood I can find from Lowe's or Home Depot and rolling a 50/50 acetone and fiberglass resin on both sides, several coats to penetrate and seal, then use joist insulators on the aluminum contact points. I would be coating all holes drilled for the stainless hardware also. Any thoughts on that? Thanks!
