Mikered3500
- Joined
- Jun 11, 2018
- 80
Hey guys. It seems my 98 ocean pro is not running 100% or starting i should sa . It is a real PITA to get it started for the forst time at the ramp and then the rest of fhe day it fires right up. Normal starting procedure, pump primer bulb til its hard to squeeze, trim motor all the way down, turn key to push Choke in for a few second (it does click when engaged) and turn the key over to start. It turns over a few times and sometimes spits out the prop and the starter just spins. it repeats that a few times til it eventually fires or it repeats that many times until it sputters to life. It bellows out white smoke for a while then cleans up just a little. Is this normal for these motors? I feel like this should start much easier. I changed the plugs this spring when i bought it. Old ones were oil bathed but still ran someho . New plugs are champions QL78YC gapped to .30.
Thanks guys
Thanks guys
