2000 Johnson 250 hp ( not a FITCH ). I keep wanting to think it's sucking air somewhere. Runs good from WOT to around 8 mph, any slower it wants to stall. You pump the bulb primer before it stalls and it smooths out for a few minutes then it starts again. ( Note: it'll idle all day in the yard on muffs. ) It was acting this way when I bought the boat\motor last spring.
Everything is new from the tank to the motor: fuel filter - seperator - new fuel lines - primer bulb replaced twice - new fuel pump new fuel rail - new fuel lines on all carbs - fresh ethanol free gas always. Can see no fuel leaks anywhere.
I've got an Atwood glass fuel filter on it - I've noticed some air bubbles in the filter even when it's idling. That can't be right - there should no air in the fuel delivery system. But I'm at the end of ideas from where it's coming from.
Motor fires right up after it stalls - no problem there. Like I said, if you catch it stalling and get to the primer bulb it'll smooth right out ( primer bulb oriented w\arrow up with flow fuel to motor ).
I thought about putting an electric Holley red fuel pump between the primer bulb and motor to have positive fuel pressure all the time toward the motor.
I've been fighting this issue for 9 mons... I've posted this problem before on another site but was reccomended to post it on iboats. Any ideas will help at this point.
2000 Sea Pro 255 CC
250 Johnson Ocean Pro
" Always have a plan. "
2000 Sea Pro 255 CC
