Ocean safe?
brogsie
I have an Avon R310 with a plywood floor and a 9.9 nissan. I now use it in a protected harbor area. Is it safe to take this boat to the ocean side (Buzzards Bay, MA). I know it would be a wet ride but will this boat be able to handle the waves?
Thanks
tashasdaddy
Re: Ocean safe?
if it is like this one, you won't catch me out there.
bayman
Re: Ocean safe?
If I were with a group of boats with other trained mariners I might consider it on a good day, staying close to shore. However, the 310 is quite small for the ocean. It does have good flotation though and will float if flipped. If the boat is flipped over though you have to make sure your outboard and all of your gear is tight and secured. Even so, most people who get flipped over end up losing a number of things. Are you going to have a waterproof radio to call for help in case things don't go well? Or, do you have an ePIRB etc..? Lots to consider. Overall, I would not recommend it. Even so, many sailors do choose a boat like yours as a tender and as a backup, should their vessel go down close to shore. If you do take it to the ocean, I would take a quality boating safety course before venturing out on the open ocean.
TOHATSU GURU
Re: Ocean safe?
It's not unusual to see 9" inflatables 10 miles from shore when people island hop, but it is a small target to spot in a big pond.
brogsie
Re: Ocean safe?
Thanks Guys,
Deejay cee, your pictures made me think that the inflatables are able to handle some good size waves. Guess I'll just be carefull.
Whoopbass
Re: Ocean safe?
My 9' inflatable takes waves better then my aluminum boat.
They are very safe just floating around but when the chop kicks up these short boats are a pain to get back in because they are to short to pass over the waves.
You will get wet motoring back in choppy water.
Nos4r2
Re: Ocean safe?
Dont' do it. The Avon Rover was only an upmarket yacht tender. If it was an Avon Sportboat it'd be a different prospect.
Dry Diver
Re: Ocean safe?
I know that this was originally asked about an Avon 9', I am new to the inflatable world. I just purchased an Achilles 16'. How does this compare as far as ocean safety. I will be using the boat for diving purposes.
bayman
Re: Ocean safe?
Dry Diver - While others on here have far more ocean experience than I do, I think the boat would be fine unless it is too old. Probably of more importance is the experience of your crew and backup equipment.
Dry Diver
Re: Ocean safe?
What is considered too old. The boat that I have has been holding air with no leaks for a month now. There are no rips tears or damage that I can see. What do I need to be concerned about.
Please forgive my ignorance about inflatables, just another newbie trying to navigate through safely.
flwestcoastboater
Re: Ocean safe?
Take that boat in the ocean! I take my little Sevylor boat which says "Do not exceed 900 feet from protected waters" into the ocean all the time! Stay on top of things though, or you WILL flip
SnappingTurtle
Re: Ocean safe?
As the owner of the boat you are not only responsible for yourself, but for the lives of your passengers. In the case of an accident it will be you, and you alone, that has to answer for your actions. No one here will be by your side to help, or to take responsibility for any of their “Go For It” responses.
The photos of the wild & crazy shots from deejaycee are for the most part race or competition events, and as such are close to shore, and with all the professional assistance that come with such events. These are people with alot of experience in such conditions, and there are still accidents. In the races I have seen, it is not uncommon to see flipped boats, not something you really want to do offshore alone. Anything on board, could or will be lost. Diving equipment is not cheap, neither are lives.
Don't confuse organized near shore race events, with independent offshore diving trips. The one, has nothing to do with the other.
All that said, if you are a risk taker, or an adrenaline junky, there are few other sports that offer the same rush, for the cost. But like all extreme sports, that rush comes at a price.
jnewtonsem
Re: Ocean safe?
Dry Diver- I think the key is is the boat in good shape. Achilies is a good brand boat, hypalon material. If its held steady air for a month, a good sign. Take it on a few runs and see what it can handle and get confidence in it. You're probably ok if you are careful and use common sense.
I've got an old 15' Avon and feel its very seaworthy, not the most comfortable ride, but not dangerous. Make sure its properly inflated, if underinflated will fold up on you in waves.
Dry Diver
Re: Ocean safe?
Thank you every one for your replies. I am really excited to get this thing out in the water. Just re powered it with a 40HP Merc. Should be a blast.
bkatz
Re: Ocean safe?
I am a newbie, but I was under the impression that an Inflatable would handled very well in the ocean? I just bought a 13? Inflatable with an Inflatable V hull for use in the Ocean. I plan on Diving from it. I didn?t plan on going too far off shore but maybe a mile or so. I have a gps, submersible marine VHF, and all the safety equipment. Is this something I should re-think?
jnewtonsem
Re: Ocean safe?
I think you'll be fine as long as you use your head. Inflatables are very seaworthy but they are still a small boat.
