oceanrunner 200 hp carb adj
toghog
Hello, I have just done my carbs and have set the adjustable low idle circuit 6 carbs at 2 1/2 turns out (manufacturers requirements) after doing that I had a buddy run boat at 1000rpm,in gear while I adj each carb for peak rpm's.They all seem to be within the 2 1/2 > 3 turn's out. Motor runs great at all ranges .It will attain wot 5000> 6000 (5800). Is there anything else I need to do to make sure that the carbs are set up properly?. I want to make sure that I am not going to cause any future problems. thank you for all advice
JUSTINTIME
Re: oceanrunner 200 hp carb adj
wot for 30 seconds with new plugs
then look at the color of the plugs
