octane booster
GARnott
I heard some people telling me that octane booster,is good for a 2 stroke engine. I have a 40hp big twin evinrude 1969 all rebuilt, Is it really good or if it could (EDIT: foul)up my engine.<br /><br />thank you
roscoe
Re: octane booster
Octane is the resistance to detonation under compression. Since most outboards are not high compression engines, additional octane will be wasted. So octane booster would be a waste of your money.
walleyehed
Re: octane booster
Double Ditto....waste of money, and actually less performance....
wilkin250r
Re: octane booster
Triple, no...<br /><br />Quadruple, no...<br /><br />How many dittos are we up to?<br /><br />Many people think octane equals power. Nothing could be further from the truth. As pointed out, octane is just resistance to detonation, it won't give you more power. In fact, there are many additives that will increase octane and DECREASE performance, increase engine deposits, and eventually cause problems after prolonged use.<br /><br />Unless you are running high compression, you do not need higher octane. And if you ARE running high octane, get a high-octane race fuel from the start instead of trying to "add" octane after the fact.
sorrydog
Re: octane booster
I doubt it would a thing for ya (good or bad).<br /><br />Most octance boosters scam us by saying they raise octane by 5 or what ever points. But a point is actually .1 of what we see at the pump.<br /><br />Yes, most outboards don't need it, but for the few that do (like V6's with cut heads or merc inline 6's) then I've heard good things about one called Coxoc. However, it will always be cheaper to get good gas at the pump if available.
