Re: Od Adding oil
Those outdrives use regular motor oil and you fill them from the top, not from the bottom like Mercs. There's a hollow screw on the forward right corner of the cover. You can remove that and add oil from there but leave the dipstick out for a vent. Check your o-rings and gaskets, or better yet, replace them once a year when you do the pressure test.
