sidechoke67
- Joined
- Oct 24, 2007
- 244
I have a 2001 Glastron SX 175, with a 3.0L Volvo Penta. Last year, my original Volvo starter started acting flakey - working sometimes...working all the time when I lightly tapped it with a wrench. So, I ended up replacing the starter with an Sierra equivalent starter. When I got the starter, and first put it in, I heard a metal-on-metal grinding sound - like the gears on the pinion weren't meshing with the fly wheel correctly. I took it out, and called Sierra, and they assured me the starter is the right one for my motor. While it was out, I laid it side-by-side with my original Volvo starter, and they were almost identical - but there was a few millimeters difference where the pinion opening lined up. So, I installed the Sierra starter again, and it worked fine.
The Sierra starter worked great all last summer, and this Spring...until today. I was out tubing with my kids in a nearby lake, and after a few stops and starts, I got that same metal-on-metal noise when I turned the key. I didn't push the issue, and came back to the launch on my trolling motor.
So...I'm not sure what to do next. I am assuming my problem is due to the few millimeters difference between where the pinion lines up on the two starters (never had this problem with the original starter). My guess is that I can loosen the starter, and re-seat it to get it to work again...for a little while at least.
So...I could buy another original Volvo starter for $400, or try another OEM brand for $130 or so, or potentially try to fabricate something to get my Sierra starter to line up better.
Anyone have any advice or gone through something similar? I could live with spending $400 for a Volvo starter if it is going to solve my problem...our summers are short in upstate NY, and it is killing me that I'll miss time on the water due to a starter problem for the 2nd summer in a row.
Thanks a lot for any info, advice, etc!!
