Alright fellers, This one kinda freaked me out. I've never seen anything like this before though. As I posted last week, I have a 1988 Merc 5.7 that I'm in the process of rebuilding. Had a timing issue, got it fixed last week with some help from you guys, so here I am again.
I've been running it in short bursts, no more than 10 seconds at a time because the water jacket wasn't finished. It's on a pallet, so no worries about the water pump. Anyway, I closed it up and pulled it outside, hooked up the garden hose. Went to start it, she cranked about a half turn and locked solid. And by solid, I mean to the point that it split the bendix drive right in half, ripped the starter casing in two, bent both starter mount bolts, and basically completely destroyed the starter. Made a few phone calls through my tears, and I ended up pulling the spark plugs out. Port bank was fine, for the most part. STBD bank all cylinders were full to the gills with water. It eventually loosened up the motor, and I got all the water out. I don't think there was any major damage to the bottom end, but I wont know until I get a new starter. I still can't turn it on the front bolt, but it turns pretty easily with a crow bar on the flywheel.
My next plan is to take the STBD exhaust off and put the water back on. My idea is that this will determine if this is a broken exhaust or a broken head. Basically by removing the exhaust completely, if the cylinders fill up with water again, it's obviously a break in the head. I had the heads tested and they were ok, but that dosen't mean a leak didn't open up somehow. My brain is leaning toward an exhaust failure, but I think this will make sure. Obviously the two aren't mutually exclusive, it could be both.
I guess what I'm asking the group is if there's anything I should be looking for along the way as far as possible damage. Basically any advice would be helpful. This kinda spooked me as this motor just about jumped off the pallet.
