Doneysitdown
- Joined
- Jul 5, 2011
- 49
Hi all. I have a mercruiser 140. 1988 drive. Serial # 6714883. Story goes at the end of the season last year struck a rock with the out drive. Boat stopped moving. Lifted up the drive and found that prop did not spin at all. Forward or reverse. Got towed back got frustrated and winterized it. Fast forward to now and I have the itch to get the repairs started. Checking out the boat again when the boat is in neutral the prop spins freely. In forward gear. Ccw it grabs but if you turn it more it sounds like rubbing your finger on a window with moisture on it. Reverse gear is the same only opposite direction. I did check the prop hub and it is fine. I know it's more than likely a bad break. Just trying to gauge if it's more the lower unit or the upper gear housing. Also wondering if it's more economical to fix myself, buy new or used, and where to go for parts. Thanks in advance
