Oh, my cracking block!
Fouled Plug
Ensign
Actually, it belongs to my brudder-in-law. Yamaha 90 has a crack in the block behind powerpack that weeps water. He currently has applied the finest product JB Weld makes, and it's holding for now (I know! I know!) Can it be sucessfully welded? What method would be applicable to a powerhead, MIG welding? I don't know exactly what alloy is used. It's too nice of a motor to toss, and he won't get a new block or rebuilt powehead despite my advice. Can it be done? Thanks!
12Footer
Re: Oh, my cracking block!
Yes, it can be welded 99% of the time. The other 1% would be because it is in a bad spot. Any good welding shop could do the job for him.<br />And it doesn't matter what alloy it is,provided it ain't cast iron (which would be strange)...And even then, there are some really great welders who whould be able to.
Walter
As lightweight as those engines are...I also doubt the block is cast iron. But even if it was I agree that it could be welded. Problem is, it would have to be pre-heated first... which means the engine would be torn down to the block. Heck...after going through that much trouble, I'd just buy a new/used block.<br /><br />Walt
PaulW
If it is an alloy, there is a product in the UK called Lumiweld. I've used it to repair broken aluminium crankcase and gearbox castings and it is magic stuff. <br /><br />It is not a true weld, I suppose strictly it should be called aluminium brazing, 'cos you don't quite get the alloy up to melting point. <br /><br />If you can cet hold of it, I'd be fairly confident that it will do the repair. I recently used it to patch a hole in a very awkward part of a friends motorbike gearbox casing, by using fire cement to support it while it flowed across the gap.<br /><br />PaulW
