MajBach
- Joined
- Jun 21, 2003
- 564
Hi again, everyone. Here are the deets:
2002 Maxum with 5.0L Mercruiser with approx 500 hours. Hasn't been run in 2 years but was stored properly. I had some problems with heavy water contamination earlier this year in my home fuel supply so I checked my fuel tank in the boat prior to starting and it was fine.
It took the typical a lot of cranking over before it started. I cranked it 10 seconds a couple of times, then paused, then gave the throttle a couple of pumps and left it open by about 50%. When I tried the third time, it coughed once or twice then backfired. Or made a sound similar but not the same as a backfire. I stopped, took a look around, remarked to myself "it's never backfired before", then resumed trying. This time it fired but not enough to keep running on its own without continuing to crank over. I saw small amounts of blue smoke - as it does every year. Then it ran on it's own, albeit with the clicking sound.
The sound it worrisome - not like any I have ever heard and it's loud even at idle. It is definitely tied to engine rpm but not completely consistent in volume such being it may be really faint or even skip a click every 10th revolution or so. The volume of the sound increases exceptionally with rpm and even a little goose on the throttle sounds like the thing will explode.
The only thing that comes to mind as I write this is to wonder can too much oil in the crankcase cause this. I had a little over half of a 9.5 litre jug of oil that I dumped into it. I can't recall what the oil capacity is on the engine but I figured it's at least 5 litres.
Any idea on what I should do next (after I check the oil)? Below is a link to 2 sound clips in two different audio formats to listen to.
Thanks
https://drive.google.com/drive/folde...eB?usp=sharing
**UPDATE**
After writing the above I went and checked the oil - fine. I then started it again. Started fine but the clicking noise took 10 seconds before it returned. The engine died - I restarted and it ran fine for a few seconds then died again. Restarted and it ran fine continuously but with the clicking. I looked deeper to see if I could locate the sound. The carb! Most definitely in the carb. The chamber was acting like some resonator ( I had the flame arrester off). When I placed my hand over the carb, the noise was very muffled. When I put the arrester on, also very muffled albeit very much noticeable.
This is perplexing. How can this be related to rpm but inside the carb? There is some type of electrical unit on the side of the carb. What does it do?
Thanks
**UPDATE**
