Re: Oil Alarm
Let me help you with a little theory.
The oil pump has a rotation sensor in it. It pulses when it's turning.
The ignition sends pulses to the coils when the engine is running. The wire you asked about is wired to one of those coil signals.
The module compares the 2 pulse trains. If both are either missing, or there, all is good. If one is there, and the other isn't, the alarm is supposed to sound.
In addition, there is a low level switch in the engine oil tank. It is supposed to close the circuit if the oil level goe down even a little. The purpose is to tell you you forgot to add oil to the boat tank, and you have 1/2 hour at WOT to get back to the dock.
You can disconnect the tank switch if it's setting off the alarm. That's considered a test for a faulty switch.
It takes more elaborate diagnostics to check out the pump rotation sensor, but it's in the maintenance manual.
When power is turned on, if the tank switch is open (normal) and the rotation sensor is connected, and the module is good, it should beep 4 times.
If I had to guess, I'd say your module is bad. I would, however, do all the tests in the checkout procedure before I let go of enough money to buy one.
hope it helps
John
