Is there an adaptor for changing the oil? Something that will connect to bottom and help drain oil somewhere instead of bilge area or by pump. What is the best pump to use. I am concerned about not getting all the oil out with a pump.
well my answer is two fold, first I attached a 45 degree angle elbow to my oil pan, then a hose with a plug, the hose was long enough to go through the plug hole, it worked ok, but took a while to drain, I purchase a pump from west marine, with its own oil drain tank, the hole goes down the oil dipstick, and it sucks ALL the oil out very good, I would recommend going the pump way
