Re: Oil Change Kit
I Fail to see the Need for any Safety Systems.........<br /><br />Properly Installed,......Nothing Short of a Hammer is going to make it Leak.............<br />There's No Pressure,........ Just Gravity.....<br /><br />Mine is a Self-Engineered System,... Of Course.......<br />My pan fitting goes from the 1/2"fine thread at the pan to 3/8ths" pipe,... Then a built to size 3/8ths" Hydraulic Hose, 3/8ths" pipe threads on both ends,...... to a Pipe Cap....<br />The hose is long enough to either go out the bilge drain,.. Or to reach up beside the engine......<br />The Pump is the Key to the system.....<br /><br />Ayuh,....Charlie, When I rebuild this barge, Mechanic Access was
Priority 1......... I can reach Every Bolt on My Barge.......
<br /><br />My Oil Filter is in the stock position,... Plain as Day when the cover is pulled....Same with the fuel filter......
