michaeli84
- Joined
- May 26, 2009
- 80
hi guys, i was wondering what pump do i need to change the oil in the lower unit? And also what kind of oil does it take. Alfa 1 merc 140. Thank you!
yep, well worth it. don't know about walmart though... not my store to shop in....The pump is about 6 bucks at Walmart.....well worth it.
another for sure, do that. also, be sure the old gasket is removed. they (the old gasket) like to stay with the drive when ya remove the screw and have to be peeled out of the recess they sit in. 2 gaskets will likely leak..Make sure to use new o-ring gaskets on the drain and fill plugs.
