Oil Change on DF 115's...
Guido4198
What type of wrench does the drain plug require on 2001 115 4-stroke.??
One of mine is kinda buggered up, and I'm not sure what "Should" fit.
Also...how good are the units that pull the used oil out through the dipstick hole...??? Anyone ever tried one...???
Thanks...
JRJ
Re: Oil Change on DF 115's...
An Allen style wrench came with mine for the drain plug. I use a Topsider vacuum pump to get most of the oil out. Run the engine enough to get the oil warm.
I recommend you buy a Suzuki Service Manual for your engine. Good luck.
