Oil Changes
DBG
I'm looking to get into the mobile oil change business and was wondering what some of you have paid to have the oil changed on your boat.
Re: Oil Changes
I can't answer your Question,.... I do my own changes.......<br /><br />But, is there any chance you'll be doing service work up around Watertown ???<br />The Paving Co. I work for needs someone to Grease,+ inspect a fleet.... <br />3 Mack dumptrucks, Paver, Roller, Backhoe, Dozer,+ 2 tag-along trailers..........<br /><br />Weekly, or Bi-weekly would be nice.........
DBG
Re: Oil Changes
Could be a possibility. I'm still trying to figure out what my startup costs would be and if it's going to be worthwhile. If and when I do this, I will only be using AMSOIL or Valvoline. I've heard all these stories about how much better AMSOIL is, then I started running it in the truck and noticed I was getting about 40-50 miles more out of a tank of gas, nothing else was changed. Amsoil also has a nice remote dual filter setup for boats as well that I installed in my buddies 30' Baja with twin 454's.
Re: Oil Changes
When,+ If you decide to move ahead on this,.......<br />Let me know..... I'll be right here......... ;) <br /><br />I run Mobil 1, 15W/50 in My boat.......
Boatin Bob
Re: Oil Changes
I'm in Canada and I do my own but I know the going rate around where I boat is $60-$65 CDN plus cost of oil and filter and oil disposal and tax...now you see why I do my own with twins.
beezee28
Re: Oil Changes
BDG, the best thing to do is to call your local boating place and ask them for a quote on oil change and how much extra for the different kind of oil.
LubeDude
Re: Oil Changes
Im sure that TheOilDoc is going to chime on here eventually and tell you the same as I am.<br /><br />I think you will be better off stocking OMC and Mercruiser oil for the engines that are still under warrenty. I know that you can purchase it in 55 gallon drums to save money. You "Absolutly cant put an oil in another persons boat that doesnt meet the requirement for that engine. If its your own boat, thats different.<br /><br />Be Very carefull. if there is a problem with anything after you touch someone elsed boat, you are going to be blamed. Im not sure I would touch it with a ten foot pole. :eek: <br /><br />Have you checked on Insurance, you would be nuts not to have it?
Luna Sea
Re: Oil Changes
And I'm trying to think of ONE local marina around here that would let an outside contractor come in and take the easy money jobs from their service department............... :rolleyes:
DBG
Re: Oil Changes
Insurance isn't an issue, and the cost of it really isn't that bad. Valvoline and AMSOIL meet and exceed all the specs from every manufacture. Remember AMSOIL has been around since 1972 with very little advertising, I run it in everything I own including my lawn mower, Sea-doo, Ski-Doo, Truck and my Boat with Twin Merc 470's. <br /><br />I've been working on cars and what not for 15 years now. I have no problem using whatever the person wants to run really, I just prefer and recomend these two. If someone wanted to run Mobil 1 or penzoil in the car or truck I can get it, but the cost may be slightly higher as I wouldn't normally stock it.<br /><br />Now on the issue of touching someone elses boat, if I go to work on a boat and the bilge is full of oil or the boat just doesn't look like it's been taken care of, there's a pretty good chance I won't touch it. And if I do touch it and something I did causes something to go wrong, then that's what the insurance is for. <br /><br />I have run into this before though. I had someone come to me to change their oil in a Chevy Blazer that they just got. When I pulled the plug, chunks were coming out of the pan, right then I knew it wasn't going to be good. I pulled a quaker state filter off and the same thing chunks in the filter. I finished the oil change off with some good ol high detergent Valvoine 5-30 all climate and within a couple of days the motor as knocking. Had two mechanics look at it and it spun a bearing from the valvoline cleaning out the motor. I was found not at fault though due to neglect of the previous owner. The previous owner and the current owner ended up settleing on going halves on a rebuild.
PAkev
Re: Oil Changes
From the context of your post and the responses, not really sure if your idea is to concentrate on the marine arena.<br /><br />Not really sure about your states requirements, but here in PA, DER has tons of hoops to jump through which is enough to keep a one man band operation busy enough to just be doing paperwork.<br /><br /><br />I would assume in addition to maintaining an inventory of oil you would also need a means of storing and disposing salvaged oil which may also require HAZMAT permits to transport to and from your various locations.<br /><br />Your competence and experience with this line of work should provide you with an understanding of the required paperwork. Your idea sounds novel and if you can make a living at it while enjoying your work, go for it. One of the worst things that could happen is 10 yrs down the road you find someone else realized the need and is doing well at it.<br /><br />There are 3 kinds of business plans:<br />Those who HOPE things happen.<br />Those who WATCH things happen.<br />and.....<br />Those who WONDER....What Just Happened
DBG
Re: Oil Changes
PAKev, your right about everything, I don't plan on just doing marine. I have a couple of local companies that would keep me busy with their equipment. Right now the hardest part is both the start-up cost and the Department of Enviornmental Conservation. I have an appointment with them on Monday to talk about it and see what permits I need and how much of a headache they are going to give me. All in all it's probably still better than working for someone else, besides I have an accountant that does everything for me now.
Re: Oil Changes
A Digital Camera just Might be a wise investment for your new business........<br />Ya Know, Before,+ After service shots of the boat........ Dated,+ Timed of course.........<br /><br />Most Judges,+ Insurance Co.s Love Photos....... ;)
LubeDude
Re: Oil Changes
Originally posted by DBG:<br /> AMSOIL has been around since 1972 with very little advertising, I run it in everything I own including my lawn mower, Sea-doo, Ski-Doo, Truck and my Boat. <br /><br />
Are you sure that I didnt say that??? :D :D :D <br /><br />I guess he hasnt been here long enough to know whom he is addressing. :p :p :p <br /><br />Now, "NOT TO CAUSE A RUCKUS", but if you have as much experience as you claim, you should have known better than to put a high detergent oil into an engine that had chunks coming out of it. :confused: Good thing I wasnt on the jury.
DBG
Re: Oil Changes
That was a long time ago when I was just getting started working on cars and before I knew better, working at Valvoline Instant Oil Change.
LubeDude
Re: Oil Changes
DBG:<br /><br />OK, Youre off the hook. :D <br /><br />Hope this works out for you.
