Oil coming out small weep hole in bottem end?
Every time after running the motor, overnight I am getting a some oil drip-page out of a small diameter hole in the bottom end on the port side of the motor. Where could this be coming from and why? Its dark oil not the lower oil that I just changed in the lower end...
Damian
Boss Hawg
Re: Oil coming out small weep hole in bottem end?
Motor size, year, type- ect :confused:
Oh jez sorry its a 1969 Evinrude 115hp Starflite 115983e
axel2009
I have the exact same thing happening to my 79 evinrude. You are right it is not lower unit oil. I will try to check back to your post to see if you get an answer. If you do get an answer could you IM me and let me know what you found out. Hope its nothing to serious. Thanks
Sure no problem, it almost seams like burnt motor oil but there isn't oil in the engine except in the fuel?
